Posted by Mike CA on January 14, 2008 at 11:48:24 from (214.1.211.251):
In Reply to: Bolting back up the H posted by neblinc on January 14, 2008 at 10:50:32:
I've been using an anti-seize compound, as recommended to me on this board. Whether you want to or not is up to you. It can get a little messy, but I think years down the road will be worth it. And I would replace the lock washers. No reason not to.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
