Posted by teddy52food on January 12, 2008 at 17:47:13 from (209.237.111.169):
In Reply to: M magneto and governor posted by Zach Bouchard on January 12, 2008 at 12:18:02:
If the mag is timed right and the engine runs good just make 2 matching punch marks 1 on the mag &1 on the part it bolts up to. P ut it back on and if it won't start, take it off and turn it 180 degrees & install. I usually turn the engine to get all sides of the pully painted. I don't worry about getting them running again.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
