Posted by El Toro on January 12, 2008 at 16:41:35 from (64.12.116.73):
In Reply to: M magneto and governor posted by Zach Bouchard on January 12, 2008 at 12:18:02:
You can pull your mag or distributor off the engine, but you need to see where the rotor is pointing before you pull it. Then don't move the engine for any reason while the mag is off. When you're finished painting turn the rotor in the same position and install on the engine. I would make a sketch and don't move the engine. Hal PS: You can put a dab of fingernail polish where the rotor is pointing & just a small dab on the rotor so you have the right end of the rotor.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
