Posted by JT on January 12, 2008 at 15:04:30 from (70.12.233.71):
In Reply to: M magneto and governor posted by Zach Bouchard on January 12, 2008 at 12:18:02:
If you do not know what you are doing, you best leave gov. alone. The mag is easy, turn engine so it is on #1 cylinder, TDC on compression stroke, take cap off, make sure rotor is on #1 on cap, make a mark in mag there, take out, don't turn engine or mag, then put back the way it came off. It only goes back in right or 180 out. Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
