Posted by Andrew Z on January 11, 2008 at 09:45:43 from (12.76.156.68):
In Reply to: H motor value posted by Farmall47 on January 11, 2008 at 09:36:17:
I would say 350 - 550 depending if you get every thing with the engine carb, gen, gov, manifold, air cleaner etc.... If the compression is good i would say around 500 or soo if fair? depends on how much you want to sell it or how much he wants it.. I just keep in mind that a good running H can be found for 1000 - 1200 soo just my thoughts.. im not any shape or form of an expert.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
