Posted by GD720D on December 24, 2007 at 14:24:42 from (66.226.101.193):
In Reply to: oil seal posted by NCCUB on December 24, 2007 at 13:15:08:
Disconnect battery. Remove hood and gas tank. Take wiring harness loose from generator.Remove throttle linkage. Can't remember everything that has to come loose but if it is connected to the engine and the rear of the tractor it has to come loose.Support both ends of the tractor.Remove thbolts that hold the engine to the clutch housing. Roll engine forward. Remove clutch and flywheel. Rear seal retainer is bolted to back of block remove retainer. If seal is loose in retainer the retainer has to be replaced. Also check engine oil pump above and to the right of the retainer. Posssible that gasket can leak
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
