Re: Fairbanks Morris Magneto
Posted by teddy52food on December 09, 2007 at 08:06:46 from (209.237.111.169):
In Reply to: Fairbanks Morris Magneto posted by tomj windsor on December 08, 2007 at 19:04:23:
I have put them together many times. It is very simple to do but very hard for me to explain. How far away are you? I am in central Mn.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
