Posted by Janicholson on December 02, 2007 at 14:08:10 from (66.173.50.145):
In Reply to: How much play? posted by GeneMO on December 02, 2007 at 12:29:54:
Each gear has a certain amount of running clearance. In fifth, the only gears in the drice train are the ring and pinion, the differential spider and side gears, and the pinion and bull gears. (fifth is direct through the tranny) As each lower gear is engaged, the additional running clearance of that gear set, and the constant mesh gear set are added to the path. As each gear has about the same clearance, the total remains about the same. But each lower gear has more rotation to move the parts through the same clearance so the total backlash (whrat it is called) seems to grow as you place it in lower gears. Not a problem, I hope this helps. JimN
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
