Starting in fifth is pretty hard on the clutch, and I recommend a shift from 4th to fifth. Make it a slow shift, and it will grind just a little. It is best to double clutch it. Idle down as you pull it out of 4th, then let the clutch out briefly, push in the clutch and then slip it into high. This is hard to do unless practiced. Are you positive you have the carb and governor coupling together at the carb connection, it is tricky little metal fingers, and causes related problems, some of which sound like yours. JimN
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
