Items not mentioned so far include the current oil pressure (if less than 20 PSI cold, and dropping from there it is not typical and indicates problems. If it has strong pulses in the needle movement at idle, it is also an indication of bearing failure.) The changing of the oil should include a scraping around in the bottom of the pan with a wire to look for particles and shavings of metal. Oil analysis can also be done professionally to assess material in the oil that indicates failure. If it is in the "bottom" of the engine, it is probably a Main or rod, In that case it is an out of frame rebuild. JimN
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
