Posted by Trent544 on October 26, 2007 at 18:46:04 from (166.82.246.61):
In Reply to: info. on a 585 posted by Les Va. on October 25, 2007 at 20:18:27:
Had a 585 once. It replaced a 574 and was supposed to be the same power. Not even close. The 206 engine in the 585 seemed sick compared to the 239 engine in the 574. Would probably be a good loader tractor since you don't use a lot of power with a loader.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
