Re: info. on a 585
Posted by Fromjb2 on October 26, 2007 at 14:24:29 from (99.241.179.24):
In Reply to: info. on a 585 posted by Les Va. on October 25, 2007 at 20:18:27:
Hi last fall my brother bought a 3230, 2 wheel drive, no cab, 700 hrs for $9700 CND. The 3230 is same as 585 but 2 models newer.
JimB
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
