Be hard to make without using a actual rod for a pattern. End of rod that contacts flaper over pin in cylinder is a seperate part held to rod by a small pin. You also need to have the correct pin that connects cylinder rod to upper 2 point lift arms. It has a hole for rod to pass through and hollow inside for spring and metal piece to lock in notches of stop rod. Not all 560 used a hydraulic cylinder with flaper and stop pin and upper cylinder pin wasn't the same as a stop rod type. I could try a picture tomorrow if you still need one.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
