The advice below should solve the flooding problem.
However you also need to clean out the weep hole at the bottom of the carb air inlet. It's provided so the air inlet passage doesn't become filled with gas should the carb flood.
The weep hole is protected by a tiny felt filter "button" that's no doubt plugged solid too.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
