Re: Farmall H Gas collecting in Carb/Air-Intake Junction??
Posted by Andy Motteberg on October 18, 2007 at 21:29:49 from (4.143.222.162):
In Reply to: Farmall H Gas collecting in Carb/Air-Intake Junction?? posted by WonderingAl on October 18, 2007 at 20:37:52:
It may be flooded or getting too much gas. Make sure you have the carb adjusted properly and make sure the float level is set correctly.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
