Posted by glennster on October 17, 2007 at 14:04:34 from (76.224.26.7):
In Reply to: Tight Tire Bolts posted by WonderingAl on October 17, 2007 at 10:16:11:
like steven said use a penetrating oil. i like pb blaster, any autoparts store sells it. if there is paint on the threads sealing the nut, wire brush some off so the oil can creep in there. if you dont have acess to a cutting torch or impact, try a propane torch and just warm the nuts up some. this will cause them to expand, then spray em up. if i remember, the h uses a 7/8 or 15/16 nut. see if you can buy or borrow a 3/4 drive breaker bar and a socket. get the breaker bar on the nut and rock it back and forth just enough to get it to move, then spray it up some more. you should be able to get them off then. run the nuts almost all the way out, then get the wedges loose. be careful if the tire is loaded with chloride and water, its real heavy,maybe 5-600 lbs. you may have to let the nuts soak for a day or two. chase the threads with a die before you put em back on, i dab a little anti seize on the threads too.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
