Start at the fuel tank and check for flow. It must flow fuel like flowing through a sweetheart straw. If less, it is plugged up. There is a strainer in the carb intake fitting as well as other places. If the lines are OK, then pull off the float bowl and (with a pan under it) gently hold up the float and turn on the fuel. Lowering the float should produce drastic flow, if not, the inlet is plugged up. Good luck. As pointed out by Bob, the coil could be an issue. If it restarts immediatly but dies I go for fuel first. JimN
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
