Posted by F-Dean on October 07, 2007 at 09:56:45 from (67.72.98.87):
In Reply to: Antique McCormick posted by JERMITZI on October 07, 2007 at 09:33:35:
There are a lot of books on the old McCormick tractors. Tractor Supply has several. Yes, there should be a serial number plate somewhere on it, usually under the gas tank. This plate should also have the model number. Then look at the "Serial Numbers" item in the left hand column. Easiest way would be to post a picture here and let us "X-Perts" help you.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
