Posted by Jason Simmerman on September 22, 2007 at 19:50:47 from (68.236.252.138):
In Reply to: Clutch on a Super M posted by jeffalex2 on September 22, 2007 at 18:29:10:
M's if they haven't been converted to the larger super M clutch don't need to be split. You can do the clutch through the hole for the belly pump. If it has been upgraded or is a super M it needs to be split. I know the super M disk and pressure plate are bigger, but I'm unsure of what size the M vs the Super M clutch is.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
