Re: Clutch on a Super M
Posted by Wardner on September 22, 2007 at 19:25:02 from (4.154.244.7):
In Reply to: Clutch on a Super M posted by jeffalex2 on September 22, 2007 at 18:29:10:
OMG, fifth gear on an unsprung hay wagon? How many kids were bounced off or did you lose track?
M's don't have to be split. That is probably true for Super M's but I don't know. SMTA's need to be split.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
