The two springs hold the impeller shaft forward so that it does not rub on the back side of the impeller. The water pump has two ball bearings that support the pulley but, unlike modern pumps, the impeller shaft is carried on a brass sleeve type bearing. That is why there are two grease zerks. On lubes the two ball bearings. The other lubes the impeller shaft bushing. If you over grease the bushing the excess is forced into the coolant. If you do not grease it, the coolant will get in between the shaft and bushing and cause corrosion and rapid wear. Missing or broken springs will also allow the coolant to replace the grease more quickly.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
