remove the front grille, and take the cover off the top of the front bolster. it will expose the worm and sector gears. turn the steering shaft and see how much play there is at the gears. if they are worn, pretty common, you will need to replace the steering shaft that has the worm gear on it and the gear on top of the bolster. if the gear on top of the bolster is a full circle gear, you can remove it and turn it 180 degrees. if its the gear thats about 3/4 's round, you will need to replace em. also check the u-joints in the steering shaft, there are bushings and bearings in the bolster that wear out too.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
