We've got a Super A with a A-91(believe)plow.Dad said they had a hard time years ago getting it to dig in.Our point is getting wore down almost to the point of needing to be replaced.I turned the drawbar around and bolted the plow to the underside instead of on top.(Found a pic in an IH book that was so small I needed a magnifying glass to see it good and that is how it was set up.)That baby will bury to the beam now if you let it.Put a moldboard extension on it and it does a great job,better than the 311's on my 350.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
