Posted by El Toro on September 03, 2007 at 04:17:43 from (64.12.116.73):
In Reply to: h will not turn over posted by corey robbins on September 02, 2007 at 18:07:17:
The pistons may be stuck from rust in the sleeves I would pour more ATF into the cylinders and let it soak. If none of the suggestions on here free it up you may need to pull the head and oil pan and loosen all the bearing caps. Then remove one of the rod caps and use a piece of 2X2 oak and a hammer to tap on the rod to drive it out. Hal
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
