Just got done removing a radiator on a SMD . Take the steering shaft apart back at the u joint . Use a 9/16 wrench to take the bolt out . Than turn the steering to " screw " the worm gear out the front . You will have to tap it some to get the shaft to come out of the u joint . As it comes out you have to remove the woodruff key so the shaft will go through the hole . Leave everything together in the front . It will come out in one piece just fine . Clear as mud? That being said I would leave that bolt alone for now . If it is a bottom bolt you will have to take it to a rad . shop to get it fixed if I'm thinking right .
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
