Re: Steering shaft bearing
Posted by Doug Coutts on August 29, 2007 at 10:34:47 from (24.123.46.145):
In Reply to: Steering shaft bearing posted by Doug Coutts on August 29, 2007 at 08:51:07:
JimN,
Just thought of something. The shaft has welded yokes on either end, no way to slide a bushing over. Is that some kind of a split bushing?
Thanks again
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
