Re: H with no spark
Posted by Brownie450 on August 25, 2007 at 05:21:59 from (207.177.82.125):
In Reply to: H with no spark posted by vernMN on August 24, 2007 at 21:33:54:
Try putting the old condenser back in & try it. These new condensers are not 100% reliable like they used to be.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
