Posted by K-Mo on August 22, 2007 at 13:34:47 from (65.169.189.2):
In Reply to: 6v battery size posted by Mike CA on August 22, 2007 at 11:30:11:
Mike,
The H uses a Group 1, M uses Group 2 & Super M uses Group 3. I don't know if there are still supplying Group 3 or not. Tractor Supply used to stock Groups 1,2 & 3, but I believe they dropped the Group 3. I think they specify Group 2 for the Group 3 applications. This may be because the newer Group 2 batteries meet the minmum CCA rating of the old Group 3. Do a GOOGLE search on "battery group size chart". K-Mo
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
