Bingo! That one rang a bell. Unfortunately, the numbers are extremely faint. I did not even realize that they were there. I rubbed a little grease into them and can make out some of them. I can see 366306R9R (I think). There may also be an inner set of digits but they are unclear. Nothing on here looks like anything in the service manual. Does not match IH numbers or Zenith numbers, neither does it say "161" anywhere. Any help with this? Must be a pretty good carb from overall tractor operation...I think worth a rebuild if I can get a sure ID.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
