Jeff - As long as the dead battery does not have an internal short (ie. the battery charger does nothing when connected) simply jump the tractor the normal way. Once the engine starts keep the RPMs a little above idle - the generator will provide sufficient current to run the ignition even after the jumper cables are removed. (Of course if the tractor has a magneto it's run fine even at idle w/o the battery...)
If the battery IS shorted, disconnect the ungrounded battery cable and use a zip tie or similar to keep the ungrounded battery cable terminal from grounding on anything. Now connect your jumper cable to the ungrounded battery cable terminal and proceed as above.
IMPORTANT! Observe the tractor's ground polarity when jumping. Connect only + to + and - to -; even if the dead battery has been disconnected or removed!
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
