Posted by Bob M on August 14, 2007 at 18:59:59 from (69.205.124.61):
In Reply to: M Alternator belt. posted by Andy Schuppert on August 14, 2007 at 18:39:14:
Andy - I'm going from memory but recall the correct belt is an A33 (1/2" x 33"). Use this info at your own risk however(!)
If you have an old, A-section belt larger than about A36 you can quickly determine the correct size:
First swing the alternator in on it's adjustment as close to the engine as it will go. Now cut the old belt, wrap it around both the water pump and alternator sheaves and back onto itself. Mark the spot where the belt end overlaps. Then remove the belt, lay it out straight and measure from the belt end to the mark you just made.
The length in inches (rounded up to the next whole inch) will be the belt size you need.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
