Posted by Janicholson on August 14, 2007 at 18:39:42 from (71.87.39.51):
In Reply to: Re: F-12 hard start? posted by Kurt Wentorf on August 14, 2007 at 14:05:02:
Using the no data method: Pull the plug closest to the radiator put a piece of hose in the hole (or get an assistant with a thumb) and gently crank the engine until the #1 cyl begins to blow air out. Put the end of a piece of bale wire about a foot long into the cyl and continue cranking and feeling with the wire until the piston gets to the top. The coupling should click just at that point. The timing marks should also line up exactly at that pint as well. JimN
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
