Re: Farmall B
Posted by ScottyHOMEy on August 11, 2007 at 15:14:06 from (64.222.248.53):
In Reply to: Re: Farmall B posted by Dave H (MI) on August 11, 2007 at 14:31:21:
Oh, dear! Good news is there's no time like the present! You need to be at TDC on #1 to check this out and fix it, so get there like I described below. On the lifter side of the rocker is a threaded rod with a slot in the end, and a jam nut below it. While holding the slot steady with a screwdriver, back off the jam nut. (This may already be loose and what caused it to come apart in the first place.) Then use the screwdriver to back out the threaded rod until you can slip the lift rod back under the rocker without forcing anything. Pull that lift rod up out of there and roll it on the flattest surface you can find, looking to see if it is bent. It should be straight. If it is bent, you'll need to replace it, but it could also be a sign of a stuck valve having caused things to come unsprung in the first place. If the lift rod seems straight you can put it back in. It just drops into place. Before putting the rocker back over it, take a SMALL hammer and tap smartly without whacking on top of the valve and spring. Just enough to see if you can get ANY movement down and back up. If it doesn't move, or the hammer feels like it's hitting the head of a tight bolt, Or if it goes down and stays down, you likely have a stuck valve. If it does move properly, you can reinstall the and reset the clearance with the rocker. The proper gap is .017" with the valves hot. You'll finsd a lot of discussion about what "hot" is and where to set the clearance on a "cold" engine. I use .018" in that circumstance. Back your jam nut off by hand a turn or two, and line the rocker arm back up over the lift rod and valve stem. Using your screwdriver, thread the rod back in until you get just the slightest tension on a .018" feeler gauge between the rocker and the valve stem. Holding the thread right where it is with the scredriver, tighten down the jam nut. As far as the gunk, it's run with it so far. If you plan to go back in and check the valves "hot later, I'd leave it there for now. At some point, though, you need to go at it with some kerosene and a stiff parts cleaning brush, and don't spare the kerosene. It will all run back down to the crankcase, so you'll need to change at least your oil (before running the engine -- let it drain while you're checking your timing, and don't forget to put the drain plug back in before refilling!) and then do another change with filter after ten hours or so of running.
Home
| Forums
Today's Featured Article -
Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
