Re: Field resistor Partnumber
Posted by Janicholson on July 31, 2007 at 19:00:13 from (66.173.50.185):
In Reply to: Field resistor Partnumber posted by Rexalot on July 31, 2007 at 12:28:57:
Rex, there are two resistors on the old LHDB light switch. One is for the lights, ant it is only used for dim lights it is located between two terminals, one of which connects to the lights. When the switch is turned to D, the light power goes through the resistor (a replacement would be a 3 or 4 ohm power resistor (ceramic wire wound) with about 80 watts of capacity. This can be soldered into the connections with short # 12 high temp wire (from appliance repair) By the way, the lights should work without the resistor on B. The L and H positions are for a three brush generator with a cutout relay only on the side of the gen. This depended on the operator to adjust the charging rate during the day to prevent overcharging (turning to L from H) A resistor is also used in that circuit, for the L position to ground the field through the resistor to ground. This is totally separate from the light switch connections. The same type 3 or 4 ohm resistor can be used for this, (could be 50 watt, but does not matter) wired in the same way. Use of a good ohm meter to make sure which connection is which is a good idea. I would use a later model real voltage regulator to make it better, see Bob M's diagrams. JimN
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
