Re: adjusting valves on H
Posted by Wayne in MN on July 23, 2007 at 20:18:21 from (71.13.41.163):
In Reply to: adjusting valves on H posted by Curtis E on July 23, 2007 at 16:37:09:
Valve adjustment process—Farmall 4 cylinder: Firing order 1-3-4-2 1. While slowly turning the engine with the crank, watch when #1 cylinder (front one) exhaust valve closes and #1 intake valve starts to open. That is when the piston is at Top Dead Center (TDC). Note: the timing pointer should be lined up with the I I mark (double line) on the front pulley. 2. Rotate the crankshaft exactly 1 rotation to put the #1 piston at TDC again with both valves closed and ready for adjustment. Adjust the valve to rocker arm clearance so the feeler gauge has a slight drag as you pull it out. (check specifications for correct amount) Be sure to tighten the lock nut!! Note: this is where you can set ignition timing also. 3. With both valves set on #1, rotate the crankshaft ˝ turn and #3 cylinder will be in position to adjust it’s valves. 4. One more ˝ turn of the crank and #4 valves can be adjusted. Note: the timing pointer will be at the I I mark again. 5. Once more turn the crank ˝ rotation and #2 valves can be set. 6. Re-check all lock nuts, install a new gasket, and you are done.
Home
| Forums
Today's Featured Article -
The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
