Re: HELP !! 300 UTILITY
Posted by D Slater on February 17, 2007 at 20:21:34 from (205.188.116.133):
In Reply to: Re: HELP !! 300 UTILITY posted by D Slater on February 17, 2007 at 19:03:27:
Jay,see if this is understandable. On tractors with no T/A or live pto power for pto goes through clutch shaft trans, input shaft, constant mesh gear and counter shaft which drives pto shaft. For live pto tractors power goes from pressure plate through a hollow shaft with gear made on shaft.(clutch shaft to drive trans or T/A goes through it) Gear on shaft drives a gear on shaft in lower center housing this is connected to another shaft that goes through hollow counter shaft then another shaft from there to pto. On tractors with a T/A and no live pto power to pto is much like live except instead of the hollow shaft and gear from pressure plate that turns whenever engine runs there's a solid shaft with gear made on it to turn lower pto gear. The solid shaft is powered from clutch plate and shaft is also connected to T/A input shaft. Reason they powered non live pto that way with a T/A is because if powered through transmission like no T/A tractors the pto would slow down with T/A in low. With live pto and no T/A power to transmission is same as no T/A and no live pto. Hope this is understandable.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
