Re: Adding hydraulic output to 340U
Posted by TDK on February 05, 2007 at 19:03:42 from (64.12.116.71):
In Reply to: Adding hydraulic output to 340U posted by PaulW_NJ on February 05, 2007 at 08:31:43:
You could use the diverter valve as Pete says, but depending on their cost, you may be just as well off finding another factory valve to fit your tractor. Not sure what the 9 gpm pump will pull. What I am sure about is, a 10 gpm/1500psi pump on a 300 will split firewood. We've used ours on the above tractor, a 504 w/12 gpm pump and a 484. The 484 is appox. 2400 psi. Can't tell any difference in either. It may be slower than the pto driven pumps mentioned, but it'll keep one person busy enough. Unless you're selling firewood for a living, then I doubt you need the pto pump. Two people can cut and split quite a bit of wood in a day. Bottom line is - How much do you want to spend to split wood ? Good luck with whatever you decide.
Home
| Forums
Today's Featured Article -
Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
