Re: 1066 clutch shaft oil leak
Posted by the tractor vet on February 04, 2007 at 17:38:41 from (76.212.225.234):
In Reply to: 1066 clutch shaft oil leak posted by Gerald Malin on February 04, 2007 at 14:17:04:
Well either the new bearing is not holding or the splines on the input at getting bad or the splines in the pressure plate have ware or you are damagen the seal when you put it in . Just how do you get the tractor back together ???? do you mount the clutch to the flywheel and fight it together or are you hanging the clutch assy. on the input and sliding the tractor back together . The propper way to put a farmall back together is to remove the pressure plate and the disk and depress the pressure plat fingers and lock them down with either thick washer or square nut or anything that will hold the release fingers down then place the pressure plat on the PTO input shaft then the disc on the transmission in put slide the tractor back together then after the bolts are all in and tight then you go up thru the inspection plate and bolt up the clutch and make sure that you remove ALL the hold down pices.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
