Re: 300U Hyd?
Posted by Unreserved dick on January 21, 2007 at 09:42:40 from (4.228.129.24):
In Reply to: Re: 300U Hyd? posted by Janicholson on January 21, 2007 at 08:08:46:
Afraid I have to disagree with Jim a bit on this. The 300U (and probably the other hundred-series models as well) have an unusual hydraulic system different from the typical "open-center" and "closed-center" varieties. The 300U's system actually has THREE ports to worry about: supply, return, and control. The most straightforward way to adapt to a generic logsplitter is to come off of one of the original IH control valves on the tractor. If the splitter includes an open-center control valve to select among forward, reverse, and idle, it will be necessary to tie that control valve handle on the tractor into one of its "on" positions to supply hydraulic pressure to the splitter's control valve via two hoses (supply and return). The IH control valve will take care of the control line in this case. I suppose it's remotely possible to do the tapping into the hydraulic reservoir block that Jim talks about, but you'd also have to tap the block to pick up the control port as well, and then tee it into the return line. This would get the pump to supply high-pressure hydraulic fluid to the splitter (through supply and return hoses hooked up to the other two ports) as well as keeping hydralic fluid from flowing out of the open conyrol port all over everything. This approach would be a kludge at best, and I'd strongly recommend avoiding it. Hope this helps. Good luck.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
