Another Auction-IH Goodies
Posted by kfox on October 25, 2006 at 13:09:52 from (63.18.233.145):
In Reply to: Upcoming Local Auction W.C. Indiana posted by kfox on October 25, 2006 at 13:02:42:
TRACTORS: McCormick Farmall 450 Tractor with torque amplifier, live hydraulics and quick hitch (two owner); 2 ea. Farmall “M’s”, 4 cylinder gas tractors (one has 2 new rear tires); Farmall 560 Tractor, 6 cylinder gas engine, rear wheel weights, suitcase weights, 16.9-38 rear rubber, shows 2262 hours; 2N Ford Ferguson (restored), 9.5-32 inch 6 ply new rear tires (must see to appreciate); Farmall “H” with good paint and new battery; IH Farmall “A”, 12 volt start, 4 cylinder gas engine, wide front end with 5 ft. belly mower, draw bar and PTO; Kubota G5200 diesel 2 cylinder riding lawn mower. TRUCKS: 1996 Chevrolet 3500 Series 1 Ton flat bed truck with gooseneck hitch, 350 V-8 engine, 4-speed standard transmission, custom bed, good rubber; 1991 Chevrolet dually club cab Silverado with gooseneck hitch, 108,000 miles, 454 cu. in. gas engine, sun visor, automatic transmission, AC, tilt, cruise, locks; 1979 Model C-60 Chevrolet Custom Deluxe truck (for parts), 4-speed with 2-speed axle, tilt 20 ft. implement bed, (no rollback); 1961 Ford F-100 Custom cab with cab and truck connected, 3-speed on the column, 8 ft. bed, V-8 292 V-8 cu. in., Holly 4-barrel carburetor; 1975 Chevrolet C-50 Custom Deluxe, V-8 engine, dump bed, 4-speed transmission, 2.5 ton truck, over 100,000 miles; 1980 GMC fuel pincher diesel 5-speed transmission with 2-speed axle, tandem axle, with an air-lift tag axle, no bed; 1985 GMC 6000, 4-speed with 2-speed axle, V-8, 427 cu. in. gas engine, no bed, single rear axle, good rubber & new battery; 1960 Dodge 600 with 16 ft. dump bed, metal 64 inch grain sides, V-8 360 cu. in., power steering, power brakes, new battery, runs well; 1985 Ford F Series, chassis tandem axle line truck with outriggers, front winch, Caterpillar 3208 diesel engine, hydraulics are good; 1974 Ford LN700 Series Truck, 4-speed transmission with 2-speed axle, 390 V-8 gas engine, good rubber, 14.5 ft. dump bed & wood sides; 1972 Ford LN600 Series with no bed, power steering, power brakes, single axle, 4-speed with 2-speed axle, 391 cu. in. gas engine; 1988 Chevrolet 1-Ton Truck with V-8 (454 cu. in.) gas engine, single tire, 8 ft. bed, automatic transmission, AC, PS, PB. TRAILERS: 1985 Model Lazy N 4-horse trailer, tandem axle, feed manger and tack storage; 17 ft. X 6.6 ft. pull type flat bed trailer, 2 inch ball hitch and a crank winch. EQUIPMENT: Rubber-tired 100 gallon spray tank; IH 13 ft. 3 pt. hitch chisel plow; 2 ea. 3 pt. hitch bale movers with 3 prongs; pull type grade maker with hydraulics (scraper pan); 200 gallon spray tank with quick hitch; pull type on rubber sickle bar mower; 12 ft. lift-type rubber tired disc; 10 ft. rubber tired double gang disc; 8 ft. 3 pt. hitch directional blade; 8 ft. quick high blade; 3 pt. hitch 6 row square beam Westgo cultivator; 10 ft. Culti-packer; 18 ft. fold-up wing drag harrow with rubber tires and hydraulic cylinder; IH pull type trip plow with rubber tires and 3/16’s; 3 pt. hitch 10 ft. winged harrow; 7 ft. pull type rubber tired Bush Hog; Wrecker winch; 8 ft. 3 pt. hitch blade; 5 ft. belly rotary mower; IH hydraulic sickle bar mower with 3 pt. draw bar hitch; Bush Hog 8 ft. rotary mower with rubber tires and hydraulic cylinder; Case 6 ft. rotary mower (for parts); Ford 7 ft. rotary mower with broken gear box. TRENCHER: Ditch Witch M422 ditcher with 2 cylinder gas engine, walk-behind type, pull start, all on a trailer. AIR COMPRESSORS: Ingersoll Rand 185 Series John Deere 4 cylinder diesel engine air compressor with electric start on a trailer with a pentle hitch; Perkins 4 cylinder gasoline engine air compressor with 2 tanks. GATES: 20 ea. 11.5 ft. X 5 ft. gates. MISCELLANEOUS: Stationary sand blasting tank; sand blasting tank on wheels; 80 gallon rectangle fuel tank with electric pump; 5th wheel semi hitch; forks for a backhoe; Farmall tractor fenders; Ford tractor bumpers, wheel weights and fenders for 8N and 9N; 2 ea. Livestock water troughs, (3 ft. and 4 ft.). 10-28-06 www.jswalls.com
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
