Re: adding water to battery
Posted by JayWalt on October 16, 2006 at 08:42:05 from (24.223.138.48):
In Reply to: Re: adding water to battery posted by Bronson on October 16, 2006 at 08:10:33:
Moreover, these minerals can cause a ph change, they can interact with the lead plates, it just plain wreaks havoc on batteries. If you notice your batteries need water and it is below the plates, your battery is probably on a downward spiral. There is a small tube that comes down from the hole, add water ONLY until they reach the tube, until you can see the meniscis (sp?)(the clinging to the tube walls). ONLY add DISTILLED water to batteries. Never add acid. If acid is needed, the plates are most likely toasted (sulfated) as well. The reason you add water to batteries, is because when you charge the batteries fast (typical with the older charging systems), the water is slowly boiled away. The acid remains, so there is never a need to add acid. The acid dissapates when it sulfates the lead plates, which is when your batteries dont hold a charge. Remember, ALWAYS DISTILLED water. It's not worth ruining a $60 battery for a $0.60 gallon of water that will maintain at least 5 battries for their life.
Home
| Forums
Today's Featured Article -
Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
