Re: Farmall super M stearing
Posted by Andy Martin on August 22, 2006 at 05:27:48 from (64.219.39.195):
In Reply to: Farmall super M stearing posted by rotax on August 22, 2006 at 05:10:00:
Jim: The question has been asked many times because it is a common problem. There is no adjustment however there are some easy things to check. First make sure the u-joint is tight. Sometimes the clamp on the front of the u-joint is sliding with a worn key in the keyway. As you turn the wheel, does it move forward and back? If so, the bearing may be loose in the steering gearbox. To get to the bearing, you have to pull the grill off. Then take the big nut off the front at the top of the gearbox. Check the bearing inside. If it is bad replacing it will help. While you have the grill off pull the top off the gearbox and see if the worm gear and sector gear have excessive backlash. If the gears are tight but the sector gear moves front to back as the steering wheel is wiggled the the top bolster bearing is bad. Then jack the tractor up and try to move the front wheels side to side. If they move much the lower bolster bearing is bad. Both teh upper and lower bolster bearings are a little tough to change so you have to decide if you can live with the looseness in the steering. Good luck!
Home
| Forums
Today's Featured Article -
The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
