Re: Super M Carb
Posted by Bob M on June 19, 2006 at 08:38:24 from (151.190.254.108):
In Reply to: Super M Carb posted by Tom O on June 19, 2006 at 08:08:10:
Before you do anything else try removing the plug at the bottom of the carb bowl, then letting the gas drain into a suitable container for a minute or two. You should get a continunous, solid stream of fuel and accumulate something on the order of 2 or 3 quarts a minute. However if after the initial surge as the bowl empties the gas just dribbles out, the problem is a restriction in the fuel supply. Look for a clogged carb inlet screen or sediment bulb, pinched fuel line, a piece of junk in the tank laying over the outlet opening, etc. However if you have good fuel flow out of the bowl drain you'll need to go back inside the carb and clean out whatever is clogging the main fuel circuit. Recommend poking a SOFT copper wire thru all the passages, orifices, etc. then blowing it out with air. Pay particular attention to the orifice and connecting passages at the bottom of the bowl behind the high speed adjustment screw !
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
