Re: outer axle bearing in 300 farmall
Posted by GordoSD on June 07, 2006 at 19:32:56 from (66.115.200.140):
In Reply to: outer axle bearing in 300 farmall posted by MoMike on June 07, 2006 at 17:53:20:
I did both my H and the SMTA. Fortunately I did the H first and found that lining up that bull gear with the axle was a little (lot) tricky. Now the SMTA bull gear is about twice the weight of the H. So I made a wooden spacer block, just the size of the space between the gear and the bottom of the case. Wedged it in there before pulling the axle. It took about 10 seconds to slide that axle and housing right back in there, as the bull gear was still there perfectly aligned.
I'd replace both inner and outer. You can tell if there is wear there if you get a "lurch" when you apply the brakes.
Gordo
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
