Re: CLARIFICATION
Posted by Janicholson on June 05, 2006 at 06:49:00 from (66.173.50.69):
In Reply to: CLARIFICATION posted by TOM WINDSOR on June 03, 2006 at 23:09:42:
Dear Tom, The tin is cut to size and placed over the journal on the cylinder you are working on. It prevents hot metal and junk from getting on the smooth surface. The piston is going to react thermally to being melted, so I cannot say how much will be needed to be missing before it loosens up. Do not melt into the cylinder sleeve or you might incidently weld it to the cast iron of the block. Welding stripes of bead down the length of the sleeve at a reduced low penetration setting, but just enough to keep the arc going, will draw the sleeve smaller when it cools. Do not go through the thin sleeve when doing this as it will (as above) weld the sleeve to the casting. I would get to cleaning out the crud in the water jacket (under the cover mentioned) to see if the efforts I was going to make to remove the cylinder components was worth it. If the block is cracked around the cylinder castings from the effects of water freezing, or rust expansion, I would get a different block. It is fairly expensive to sleeve out a block to repair a cracked casting. Good luck, JimN
Home
| Forums
Today's Featured Article -
Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
