Re: 1086 POPS OUT OF REVERSE
Posted by JJK on May 21, 2006 at 13:13:08 from (216.189.131.224):
In Reply to: 1086 POPS OUT OF REVERSE posted by BILL GRIFFIN on May 20, 2006 at 16:15:46:
There may be a thrust washer gone on the reverse shaft and the gear is floating back and forth. The easiest way to check this is to first, hope that you don't have the saddle tank, or you'll have to remove it to get to the side cover above the hitch pump off to see if thats what the gear is doing. To fix that you have to split the tractor to get the shaft out to put in the missing thrust washer. Thats what I've seen for this type of problem. The only other thing that could be is a detent roller gone in the shift coveror the lobes on the control shaft are wore badly and you have to remove the seat, shift linkage, and have the tool for removing and installing the cover to check for that. You can decide what you want to check first. Personally I'd go for the side cover first and if you have a side tank just run it down to towards empty so you don't have to be draining and pumping fuel.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
