Re: Tire liquid question
Posted by Dave Sherburne NY on May 11, 2006 at 18:06:36 from (67.138.164.56):
In Reply to: Tire liquid question posted by Rick/Oasis ID on May 11, 2006 at 06:29:59:
Go to the John Deere board and read the post "filling rear tires," its #3 right now. To long to type again.me tell you how I did it on a MF 35 this spring. First you go to www.Gemplers.com and order Item no. AQF1 Quick fill tractor tire Attachment.$13.95. Next you get two plastic 55 gallon Barrels with the caps you can screw a pipe fitting in. In one cap you put a fitting with a valve in it that you can screw a garden hose to. In the other,you put a valve stem like the type found in water tanks for pressureizing the tank. Then you take your barrels and go to the local car dealer and ask if he has any used antifreeze you can haul away for him. He has to pay to have it hauled away if you don't take it Usually they wind up with oil floating on top of the antifreeze. so if he has a pump to pump it into your barrels, you can stop before you get any oil. It takes about two barrels for 12.4x28 tires Then you take it home, and leave it right on the truck. Jack up one wheel of the tractor let the air out and remove the tractor tire core housing. with the valve stem at the top, attach the adapter you got from Gemplers, and hook a hose to it. I use a washing machine hose. Install the barrel plugs in the barrel with the fittings on them. Then lay the barrel down on its side with the plug with the valve on the bottom. Barrel still on the truck.hook the hose to the barrel, and open the valve. If you put pressure to the barrel,no more than MAXIMUM OF 10 POUNDS did I say MAX 10 pounds. It took about 20 minutes to transfer the anti- freeze into the tire. When it starts to squirt out the adapter, its full, shut off the valve, remove the hose and adapter and reinstall the tractor tire core housing still leaking isn't it you should have put the valve core back in the housing while you were waiting for the tire to fill. Don't ask how I know.Next step is to inflate the tire to 12 lbs. Then do the other one. http://www.tractorsmart.com/Farm_Tractor_Liquid_Tire_Ballast.htm will tell you how much your tire holds. Good Luck Oh, Don't get that $8.25 Adapter from Napa. Its to slow. Maybe that copy &paste stuff will work.
Home
| Forums
Today's Featured Article -
Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
