Re: trans.
Posted by the tractor vet on April 22, 2006 at 05:29:12 from (64.179.117.165):
In Reply to: trans. posted by everado on April 22, 2006 at 04:45:23:
Just keep on slamen it and you'll be realy screamen on the price of fixen it > As there is no real adjustment to it if the shifter is in nuterual and ya have hi and low but rev. does not go in wright then guess what it is time to dig into your mouldy check book old coffee can or the old sock as it is time to stimulate the economy as there are parts needed to be REPLACED and also ya went and let the clutch and T/A adjustments go to long . It is like this if you have to slam and jam a shifter on a farmall to get it in or out of gear then the clutch and T/A adjustments are out and because of this theyget hard to shift and nobody realy take good care of there tractors in stayen up on adjustments . Clutch adjustments should be checked every year along with tune ups timming valve adjustments on gassers , Tractors are not a car or pickup that yua just drive them they are equipment that works in some of the worst cond. and things wear . People do not stop and think till they start to have a problem then it OH what is wrong here can i just adjust it , NOPE it's time to fix now . So what all is needed now depends on just how the tractor was treated over the years and how long she has been slamed to get rev. So you start at the top and end up down in the bottom as all the linkage needs to be tightened up and remove as much slop as ya can then it is getting into the range cover and fixen replacen what ever is loose then on down to the rev shifter and shifting fork and on real worse ones ya have to tear the whole rearend apart to replace gears and other pices and parts. So i need more info beside I HAVE TO SLAM IT TO GET REV.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
