Re: farmall H still not running
Posted by captaink on April 18, 2006 at 05:55:05 from (66.115.214.56):
In Reply to: farmall H still not running posted by jdo on April 17, 2006 at 16:06:12:
You have a plug in the fuel supply to the carburetor. Turn the fuel off under the tank. Then start by taking the fuel line off the carburetor. When you turn the fuel back on you should gave a very good stream running out of the line. If you do then check for a screen screwed into the inlet of the carburetor and see if it is plugged. If you just have a drip, take the line off the sediment bowl. Again you should have a steady stream. If you do, then replace the rubber fuel line. (Rubber lines will work, but over time can deteriorate and the rubber collapse and close off the line.) If you still only get a drip, then take the glass (or possibly metal) sediment bowl off and clean it and the screen on top of the bowl (between the gasket and the sediment bowl metal). While you have the bowl off, turn the fuel on and see if you have fuel coming out of the tank. If not, either take the tank off and tip it so that you can take the sediment bowl out without loosing fuel, or take an air compressor and blow air back into the tank though these holes. The next time the tank is close to empty, take it off and clean it out or this will happen again. Once you have good fuel flow to the carburetor, the H will run.
Home
| Forums
Today's Featured Article -
Tuning Up Your Tractor: The Battery - by Curtis Von Fange. Buried somewhere beneath the sheetmetal, under the gas tank, or stuffed in front of the radiator is the battery. This elusive and neglected component of the tractor is the hardest to get to when it is dead and in need of a jump. But usually, the storage battery is a storehouse of electrical energy waiting to be released a the flick of a switch. A few maintenance tips and periodic cleaning will keep it charged for the duration of its life span. The battery is made up of a number of lead bas
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
