Re: grounded out the generator for charging
Posted by John T on April 08, 2006 at 07:34:02 from (66.244.90.5):
In Reply to: grounded out the generator for charging posted by lekander883 on April 08, 2006 at 06:46:12:
rek, I have to agree with Allan. If you dead ground the gennys Field post that allows max charge condition which is fine if used ONLY for enough time to fully charge the battery. HOWEVER over charging n out gassing n boiling over a battery is harder on it then undercharging, and once shes charged the rate ought to back off. A) Does the tractor have a full fleged 3 terminal (BAT GEN FLD) Voltage Regulator or the simple 2 wire (BAT GEN) Cutout Relay and the light switch field current control ???? (see below) 1) VR SYSTEM: One thing you may wanna try regardless is to insure the VR (if thats what it has) has a good bond/connection to frame ground/gennys case cuz if none exists or its corroded or resistive, even a good working VR cant do its job!!! Run a good jumper wire from the VR's metal base to a good frame ground n see if she works okay then???? If so repair that n do away with your cheat ground method.
2) CR SYSTEM: If it has the simple 2 wire (BAT GEN) Cutout Relay and uses the light switch field current control method and she dont charge, the light switch may be bad or its resistor is bad or it doesnt have a good to dash bond/connection or the wires open from the gennys Field post up to the light switch !!!!!!!!!!! If the switch is good and it has a good to dash ground, thats where the gennys Field post gets it return current path for it to charge, the same thing that happens when you provide that cheat ground at the gennys Field post. I would trace the wire from the gennys Field post up to and through the switch and insure the switch has a good ground if its the 2 wire CR system that uses the light switch to troubleshoot that circuit !!!! From what you told us it seems your genny (the more expensive component) is fine so if alllllll connections are good and the wires good from the gennys Field to the switch and the grounding (light switch or VR) isnt the problem, Id be investing in a new VR or light switch as needed. John T in Indiana
Home
| Forums
Today's Featured Article -
The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
